Diagonal lines in solid hatch when printing to PDF
Odd diagonal "hidden" lines appearing when I print to PDF.  Screenshot attached.
pendean
Community Legend
Community Legend
Solid hatches are drawn in rectangles: which PDF driver did you use, did you try another, and what does ABOUT command list as your exact LT version?
Thanks for replying.  I tried printing to PDF in both Adobe and Bluebeam PDF.   I'm using Q.47.0.0 AutoCAD LT 2020.  I'm going to try plotting to Arch D on site tomorrow and see if the lines still show up.  If not, I guess I could just scan that sheet to PDF but figure there has to be a solution to avoid the extra step.
pendean
Community Legend
Community Legend
Adobe? Bluebeam?
Why not use one o the 5 built-in PDF drivers that come with LT2020 instead: DWG TO PDF is a good place to start.
FWIW you are missing the 2020.1.3 update for LT, get it and install it now from here https://manage.autodesk.com/cep/#products-services/updates
