hello-
my name is colin and i'm new to AutoCAD- I have a new windows 10 computer and trying to setup my designjet 800 to plot. I used the autocad plotter wizard but I get an error about the driver not working- I can print fine from windows but appears I can't get this designjet to plot using
the autocad LT- 2016 installed on my computer-
I don't have a support contract with AutoCAD so hoping someone has seen a work-around.
thanks,
colin
Solved by Emmsleys. Go to Solution.
Solved by pendean. Go to Solution.
Have you tried using different print drivers by any chance? Did that help?
HP design jet printer drivers:
I had the exact same issue as you, was able to fix it, this is what I did:
1: In Autocad, click in the console text bit at the bottom and type in plotter, this should autocomplete to plotterwizard or something like that, click it to open the folder of Autocad plotter templates and double click the wizard to add a new plotter.
2: Go through the wizard to add a new Autocad plotter, add it as a "DesignJet 750C C3195A" (I know we have a 800, but this works), for the port select the one your 800 is on, complete the wizard.
3: Go to print and from the drop down list of printers select the 750C (will only appear in Autocad not Windows) instead of the 800.
4: Print.
This should work fine for you too.
@ james_edge Hello and welcome to the AutoCAD LT forums!
Thanks for adding to the thread and sharing your workaround suggestion. I'm sure other AutoCAD LT user's will find it helpful.
Thanks for posting this. I looked around at several other fixes but most of them were along the lines of "try to download drivers for other printers and maybe it will work..." You are the only one that I saw that mentioned this particular workaround which fixed our problem using TrueView 2018. Using your method I did not have to install any drivers. I simply used the existing printer drivers that were already on the network.
You can't type commands in TrueView so the instructions were slightly different for us. Since I wrote these steps for my own sake I'll post them here in case it helps anyone out. Note that you may have to make some changes to these steps depending on how your environment is set up.
