My Dell Latitude 5330 is new and has the following specifications: 12th Gen Intel(R) Core(TM) i5-1235U 1.30GHz RAM 16GB Graphics Intel(R) iris(R) Xe with 1Gb RAM DirectX 12 Will the PC run current Autocad LT? I intend to make simple, not very large or complex 2D drawings. Thanks for the feedback
i5 is slower than i7 and also if it's just 1.3GHz then that does not meet the requirements:
I really only have very simple, small 2D sketches. For example, the DWG Viewer 2024 works on PC. Autocad LT will hopefully be able to run on the PC, even if not at full strength? I need a positive answer. 😉
Here are hardware requirements for dwg true view 2024
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/System-requirement...
Since this is similar to acad lt 2024 and you are able to install and successfully run DWG true view 2024 then you should download acad lt 2024 trial version and test on the same laptop too
Install LT2024 and find out for yourself @EGepperHUEN5 : you get some free time to trial it with no restrictions or purchase required, here is the link https://www.autodesk.com/products/autocad-lt/free-trial
