If Dean's suggestion does not work, post a copy the file and I will take a
look at it. Strip out everything you can that does not have to do with the
problem.
Brad
"Dean Saadallah" wrote in message
news:5794245@discussion.autodesk.com...
You have a block definition with an entity on that layer perhaps, or
paperspace content still holding on to it (or a combination of both).
Best way to delete a layer in your older version of LT is to WBLOCK out the
model content you want to create a new file, then look in there: if the
layer is still there, it's a block definition. Rename the file to something
you would use instead.
Dean Saadallah
http://LTisACAD.blogspot.com
Add-on products for LT
http://www.pendean.com/lt
