Degrees minutes second
Message 1 of 8
I am drawing lines using degrees minutes and seconds, I already set the north, but everytime I make a line it seems to be flipped, im not sure if it is mirrored. I remember reading something about inverting North and south and east and west, but I cant find it anymore.
Replies (7)
Message 2 of 8
h_s_walker
Welcome to the Forums
At the command line type UNITS.
You can change the angle from anticlockwise to clockwise there. Also click on DIRECTION. You can change the base angle there as well.
Howard Walker
Left Handed and Proud
Message 3 of 8
I already did that, before drawing, but it still happens 😧
Message 4 of 8
Message 5 of 8
h_s_walker
I just set the BASE DIRECTION to NORTH AND the rotation to CLOCKWISE and drew a line at 45 degrees going from bottom left to top right.
Howard Walker
Message 6 of 8
pendean
Community Legend
Community Legend
Show us your dwg file and explain in a lot more details what you are trying to draw and how exactly you are entering the direction in the exact syntax you are typing.
Message 7 of 8
john.vellek
Hi @Anonymous,
Here are the settings I have setup by default in UNITS.  Please attach a drawing that illustrates your question or even better, make a Screencast video to show the community how you are going through your process.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 8 of 8
john.vellek
Hi coni.nakouzi,
I am checking back to see if my post or others helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
