Since upgrading to AutoCAD LT 2016 I have been unable to use the DATALINK to Excel spreadsheets. I have gone through the help desk and had 4 different people from AutoDESK work on it, and they are unable to get it to work. The error message I continue to receive is:
"Only Excel 2000, Excel 2003, and Excel 2007 file formats are supported. You will need to save the Excel file into one of these formats."
Since we are using MS2010 here, I can't go back to 2007. It doesn't make sense to me that as AutoCAD is upgraded it doesn't allow other formats to load into it at the same rate.
Anyone out there know how to get around this?
MSExcel2010/2013 can be set to 2003 format and lower (SAVEAS from there will get you that), as can MSWord2010/2013 etc. with little or no real effect to usage: Microsoft designed them that way.
Is there a particular challenge you wish to overcome beyond that? Autodesk isn't rewriting LT2016 anytime soon otherwise. Hope that clears it up.
If your Excel templates are always 2003 format, you never have to keep changing back whenever you start an Excel spreadsheet. Takes no time at all to change them and move forward with them. Everyone that uses Datalink in AutoCAD has done so since that command was available. Seems to work quite well for us.
I'm not familiar with your other challenges: you create a table in LT first then go out and try to link it to an Excel spreadsheet?
*How about just attaching the Excel spreadsheet into LT2016 without creating a Table object first? What we do.*
You can also start HELP in LT2016 and look up the topic:
About Linking Excel Spreadsheets
It has links at the bottom to go further into the concepts.
Hello again.
Yes, I do expand that popup, and it shows all the various files I saved, varying the extensions. I have tried it. It doesn't work.
You say it works for you, with the .xls extension. I have tried it. I am stumped on this one.
HI Dorrie52,
Welcome to the Forums!
It sounds like you have been through the wringer trying to get this resolved. I went through all of your steps and brought the table into LT 2016 without issue.
When I created and then saved my Excel file I chose the "Excel 97-2003 Workbook (*.XLS)" option and it came right up in AutoCAD LT 2016 just fine. If this is not showing up in your list of file types then try going back to the Excel 5.0/95 version of the XLS as that format should work fine as well.
If none of these options are present then I suspect your Excel install is incomplete. At one point Microsoft had available for download, a utility that would provide backward conversion of Word and Excel files. That might be another option.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
Good morning Dorrie52,
I have not seen an update on your post so I thought I would check back with you to see if your issue had been fixed. If not, please attach some sample files so I can take a look and continue to work towards a solution for you.
Hi @pendean
I am one of the "fellas" and want to express, on behalf of myself and team mates, that we appreciate everything you "end users" do to contribute to the forums.
I was hoping to see your results in your post regarding the workstation refresh and whether or not it has fixed your issue. Please give the post an update at your convenience.
