Datalink formatting different from Excel file in AutoCAD
graemed
Observer Observer
graemed
Observer
Observer
I would like the format of the data link tables in the cad file below to match the excel file. As can be seen by the image, they are not the same. I have tried many combinations of data link options. Please let me know if there is an easy way to create data link tables that look exactly like the excel tables.
@graemed for clarity VStudley embedded your image directly in this post and edited the original subject: Datalink formatting
Victoria.Studley
Hi @graemed,
This looks like a known issue that has already been reported to the AutoCAD development team. It's linked to Windows display scaling, and there are couple of things you can do to work around the issue, documented in the following links:
If one or more of these posts helped answer your question, please click Accept Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Victoria.Studley
Hi @graemed,
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
graemed
Observer
Observer
There are no worthwhile solutions in the links provided, editing tables or adjusting window scaling is too time consuming. I will be sticking to OLEs until a better solution comes along.
Thanks though
