Data Links in LT
Data Links in LT
lee.pellegrin
Data Links in LT
lee.pellegrin
If you look at the attached file, on the last 4 pages there are tables on them. I would like to know if there is a way to push info from one acad file into a excel table, and then in another file use that table as a schedule?
paullimapa
Assuming those schedules shown in the PDF are actual Table objects in the dwg, then you can try using LT's TableExport command which would create a csv file for you to open in Excel:
https://help.autodesk.com/view/ACDLT/2026/ENU/?guid=GUID-EC760CA9-5BF4-4CF3-90D3-63DB194D43EA
Paul Li
IT Specialist
@The Office
lee.pellegrin
What I want to do is build a table with multiple files inserting into excel and then pull the said table into a file for the lengths to be calculated. With LT I do not have data extraction available.
paullimapa
Only option is to use full AutoCAD
Paul Li
IT Specialist
@The Office
pendean
Community Legend
Community Legend
@lee.pellegrin LT's ability are very limited to "...push info from one acad file into a excel table..." if you actually mean you have new data content to put into a TABLE first, explore the command
https://help.autodesk.com/view/ACDLT/2025/ENU/?guid=GUID-6FEA6520-430E-47E2-BA16-305508495156#:~:tex...
For tables already in a DWG file, if that is all you meant, see the excellent reply from Paul for methods.
