Cursor Lagging In Certain Spots
jason9MSBA
jason9MSBA
I have noticed in the last couple weeks that my cursor is lagging when I hover over certain areas. It seems to be just over hatch for the most-part. I haven't changed anything as far as I know. Anybody happen to know what might cause this? I have attached a video showing what I mean.
Before you reply, I have done the following and still have the same issue:
  1. Disable HPQUICKPREVIEW: Set the HPQUICKPREVIEW variable to OFF or 0 to prevent quick preview rendering, which can cause cursor slowdowns.
  2. Enable Hardware Acceleration: In the 3DCONFIG command, ensure that “Enable hardware acceleration” is selected. This can improve performance.
  3. Disable Selection Cycling, Quick Properties, and Dynamic Input: In the tray settings, disable these features to reduce overhead and improve cursor responsiveness.
  4. Turn off Rollover Tips: Disable rollover tips (ROLLOVERTIPS=0) to prevent the cursor from slowing down when hovering over hatches.
Thanks in advance for any responses.
Replies (18)
paullimapa
What version of AutoCAD?
Have you tried setting Gfxdx12 to 0 & restart AutoCAD?
Also do a snapshot of GraphicsConfig window & share that here.
Paul Li
IT Specialist
@The Office
pendean
Community Legend
Community Legend
Is this a problem in ALL of your files ALL the time? Or just this one?
Did this just start because there is something new you may have forgotten to mention from two weeks ago?
FYI, your list forgot to confirm if you turned off OSNAPHATCH (your cursor and video hint that is on).
jason9MSBA
What version of AutoCAD? AutoCAD LT 2025.
Have you tried setting Gfxdx12 to 0 & restart AutoCADNot yet, but I will now.
Also do a snapshot of GraphicsConfig window & share that here. Attached.
jason9MSBA
Seems to be a problem in other files as well, but not all. Just started a week or so ago. Like I mentioned, I didn't change anything that I know of.
OSNAPHATCH is set to 0.
I have attached another video which seems to point to the issue being more specific to only certain hatches maybe?
paullimapa
Make sure you've downloaded & installed 2025.1.1 LT.
After you've changed Gfxdx12 to 0 & restart AutoCAD the GraphicsConfig window should now show Virtual Device: DirectX 11
If the problem still occurs try changing GraphicsConfig: 2d Display Settings from Advanced to Intermediate
Paul Li
IT Specialist
@The Office
pendean
Community Legend
Community Legend
Something changed, most likely updates to video card or something, where your files are stored, or how you connect to them, if the LT2025 program did not change at all.
Your second video, much like your first, is showing only the slightest hesitation and slowness, most likely all related to your system or video drivers having changed or tweaked.
jason9MSBA
Hmm, Ok. Thanks for the input. I'll see what we can figure out.
jason9MSBA
The issue is still occurring. It slows down more when I zoom into a hatch pattern. I am thinking it's gotta be a hatch issue. I haven't changed anything regarding my graphics card or drivers. So weird that I can't find any other reference to this happening to anyone else. Unless they are describing it differently. I even just reset all AutoCAD settings to default. It's driving me crazy lol.
paullimapa
Do another screenshot of your GraphicsConfig window and share that here
Paul Li
IT Specialist
@The Office
pendean
Community Legend
Community Legend
@jason9MSBA wrote:
The issue is still occurring....
Here are the ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
HTH
jason9MSBA
Here you go.
paullimapa
That's odd that Virtual Device is still showing DirectX 12.
It should show DirectX 11 if you executed the steps I outlined in my previous reply here:
Solved: Re: Cursor Lagging In Certain Spots - Autodesk Community
Paul Li
IT Specialist
@The Office
jason9MSBA
How do I change the Gfxdx12 to 0?
paullimapa
Enter that at LT command prompt and then close out and restart AutoCAD. GraphicsConfig window should then show DirectX 11
Paul Li
IT Specialist
@The Office
jason9MSBA
Ok, there was no such command when I tried that. So I Googled how to do it and it showed me how to do it in my computer settings. So now it is showing DirectX 11. But issue still persists. I am just going to file a ticket with support.
Thanks for trying to help.
paullimapa
Odd that GFXDX12 command does not exist in your 2025 LT/
But at least you got it to switch.
But before that, try one more thing.
In GraphicsConfig window under 2D Display Settings select another option.
Also uncheck Smooth line display and see if that makes any difference.
If not, switch back to DirectX 12.
Paul Li
IT Specialist
@The Office
jason9MSBA
That appears to have helped for the most-part. I think. Looks like it still drags over dense hatch. For example, instead of using solid hatch, I use ANSI31 and set the scale really low. Not sure why. I think a long time ago I was told it would keep the dwg file size down.
paullimapa
A long time ago prior to AutoCAD adding the SOLID hatch pattern that's the case. But since then using the SOLID pattern is best.
Paul Li
IT Specialist
@The Office
