Is there a command to remove multiple layout of the Paper Space, not just selecting one by one?
Thank you in advance!!
Solved by RSomppi. Go to Solution.
Quick Select can select viewports. See the image below. And when you've selected them you can delete them.
Howard Walker
@syanchuck wrote:Where can I find this command?
Thank you!
HELP in the program will show you when you click the FIND button
HTH
not sure what you asking for, but one paperspace is one layout, one layout is one paperspace.
If you want to delete multiple layout, select them by select multiple layouts while hold shift or ctrl.
QSelect will select multiple objects in the current space.
Sebastian
>>"I have about 100 sheets, I need to delete all of them, leave only one"
Okay, you want to delete layout.
Select multiple by hold down shift or ctrl.
Sebastian
Are you using LT 2025?
too bad...if you had at least LT 2024 then we can run lisp function
@syanchuck wrote:Thank you, but it doesn't let me to select all layouts on the Paper Space, only one Viewport.
@h_s_walker The OP needs help with your tip please.
@syanchuck wrote:I have about 100 sheets, I need to delete all of them, leave only one:
Why not just use WBLOCK to create a new DWG file from all the MODELspace content you wish to keep, then use ADCENTER to drag/drop the one and only layout you wish to keep?
Then just archive this one for 'safe keeping'.
I've found that way if we would delete all unnecessary sheets by one command is much faster. I've already done it by selecting one by one anyways...
@syanchuck wrote:...I've already done it by selecting one by one anyways...
Any reason you don't just hold down the SHIFT key then select first and last tab on your screen to delete all at once?
Is this something you have to do many times a day, every day, all week long? May I ask why (what's the purpose, end result)?
Are all the layouts named 1 2 3 4 5 6 7 8 etc. like in your screenshot above?
Sorry for the late reply,.
For some reason, it doesn't work. I am able to select only one layout. The command "Select All Layout" also selecting only one.
Thanks again for your help.
Thank you. I am trying and trying again this command thinking that it might me me doing something not proper, but the command is able to select only one layout.
