CTRL + Shift + A is not working!
andrea9PAPQ
Observer Observer
andrea9PAPQ
Observer
Observer
Hi all,
For a long time I've used CTRL + Shift + A to toggle groups on and off. However this recently stopping working for me. When I use that shortcut NOTHING happens. I've checked that other shortcuts work (CTRL + C, etc). I have been running AutoCAD LT via Parallels for years and the only thing that has changed recently is that I downloaded Parallel tools.
Anyone have ideas as to why CTRL + Shift + A is not working? It's really disrupting my workflow!
cadffm
I can't talk about your shortcut, but is the current official shortcut working?
CTRL+H
Sebastian
pendean
Community Legend
Community Legend
Does "parallel tools" (or do you mean Toolbox?) create a different key combo list that is active, and you've never looked into how to deal with it for some reason? Find out, ask support https://www.parallels.com/support/
Did all keyboard shortcuts stop working? Or are you only trying/testing this one combo?
PICKSTYLE is the variable name, look up usage in HELP and see if that suddenly stopped too or if the problem is just your keyboard/key combos with your add-on.
andrea9PAPQ
Observer
Observer
Hi, I didn't create ctrl + shift + A to toggle groups as a custom command, it was my understanding that was how groups were toggled on and off. I've used this command on several different computers with different logins.
Yes I did try other shortcuts as I stated in my post. They are working just fine.
However, I have tried ctrl + H and it does seem to toggle groups on and off as well! So I can just adapt to using this while I explore Parallels more and see if there is something preventing this particular keyboard shortcut from working.
Thanks!
