ctb files
ctb files
I am trying to add ctb files. I have placed the files in the folder that is listed under the Plot Style Table Search Path, but when I go to plot, none of the ctb files saved in that folder are listed as options under the Page Setup portion of the plot pop up.
What folder opens when you select File>Plot Style Manager?
Check your default settings for file type. You may be set to use stb files. Check your default drawing. I'll bet it is an stb file. If you have an stb file as the default, the ctb files will not show in the file selection in the plot dialog box. Change your default ACAD dwg to be of the ctb variety and the problem should go away.
See attached: if you are still having problems, see mbabich's reply for the
fix.
Dean Saadallah
http://LTisACAD.blogspot.com
Add-on products for LT
http://www.pendean.com/lt
