I have tried to print a drawings and the standard CTB file that I always use is missing! Is anyone able to provide advice?
I have already
- Checked Options to make sure the file path is correct
- Restarted the computer and Autocad Lt
- Checked the folder to ensure the file is actually there (it is).
- Copied and pasted the CTB file in the same folder with a different file name
I have not changed my settings and then just randomly this happened a couple of days ago.
Curiously other CTB files that are in that folder are present. Could this be because I have used the CTB for multiple years and versions of Autocad?
Thanks for you help?
Is the drawing setup to use stb files instead of ctb? If so you would need to use the CONVERTPSTYLES command to covert the drawing for use with ctb.
