Creating Multi Coloured Line type in AutoCAD LT2016
Message 1 of 15
Hello
I am new to posting on this type of Forum!
I need to create a Multi Coloured continous Green and Yellow line(say 5mm Green follow by 5mm Yellow and so forth), to demostrate an earth cable within a set of line schematics.
I have researched and found it is possible within AutoCAD full version using the DASHED and DASHED2 line types, but i can not see how to generate within the LT version.
Does anyone know how to work around this problem?
PS - I do not know anyone with a Full version to ask them or to borrow they machine to generate!
Kind Regards
Matthew
Replies (14)
Message 2 of 15
kennyj
Welcome to the forums, Matthew74AKB.
In regards to your PS; you can download a full version of the software on a 30 day trial to test the line type creation you found and see if it will provide the solution you need on LT.  It is also a great way to see if maybe the full version offers other solutions to consider upgrading.
Hope this helps,
Kenny
Message 3 of 15
pendean
Community Legend
Community Legend
There is no option to do that in LT or full AutoCAD: can you point us to this article you found? I suspect you skipped over other things involved that you might also need to use or buy.
Message 4 of 15
h_s_walker
The way I would do it is
1. Draw a solid line. Doesn't matter which colour you choose.
2. Draw a dashed line directly over that line using the opposite colour to that you used in 1.
Howard Walker
Left Handed and Proud
Message 5 of 15
Seems pretty straight forward here:
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=1818
Message 6 of 15
Thank You, i have tried this option also, but you end up with one or the other taking presedence and therefore can not see the other colour.
Message 7 of 15
Just can not believe how hard this simple thing is!
After all you can write your own line types, i can not see why you can not define your the colours within them.
There has to be a simple method for this after all it is only a dashed line of one colour and another dashed line of another colour.
THanks.
Matthew
Message 8 of 15
h_s_walker
You draw the solid line first. Then you draw the dashed line over it.
If you see the solid line on top select it. type DRAWORDER and then choose SEND TO BACK
Howard Walker
Message 9 of 15
pendean
Community Legend
Community Legend
MLINE command: creates MLINE objects as defined in MLINESTYLE command. You are correct, LT has nothing like it at all, never has, probably never will.
I thought, since you write 'multi-colored LINETYPE" and not multi-colored parallel lines, that you wanted a single line type definition dashed or center or divide like this where each dash is a unique color - - - - - - - - - - - - - - - - - - - - - - - -
Message 10 of 15
Hi
Thanks, yes i am after a line which in effect has 2 colours Green and Yellow.
I beleive that the link which i posted up allows for this to happen.
Ie you create a line type from the DASHED and DASHED 2, where teh DASHED component is Green and the DASHED 2 component is Yellow, but they 2 are combined to allow you to have a Green and Yellow continous line.
Matthew
Message 11 of 15
pendean
Community Legend
Community Legend
Enjoy your software upgrade to full AutoCAD.
Message 12 of 15
Sadly i do not think that will be happeing any time soon!
I will need to find someone with a full version and see if they can generate the line type for me to load onto my LT machine!
Matthew
Message 13 of 15
pendean
Community Legend
Community Legend
I like Kenny's idea too about doing it yourself with the 30-day trial version http://forums.autodesk.com/t5/notifications/notifymoderatorpage/message-uid/6583940
Message 14 of 15
alexpromd
Use command _mstyle
[video]
Message 15 of 15
steven-g
Couple of problems there.
One this is generally an English language forum so trying to follow it in spoken Romenian?? would be difficult for most people to follow, I managed but.
Two you are using Civil 3D to explain to LT users how a command they don't have should work.
