AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Creating macro for blocks in Autocad Lt 2019
3 REPLIES 3
486 Views, 3 Replies
Hi all,
I was just wondering if there is an alternative set of macros that could be used in Autocad Lt 2019 that would allow me to number and create blocks?
I was using the following macros on previous versions of Autocad Lt:
^C^C_setenv;index1;\_setvar;userr1;\ - to set the numbering
*^C^C_-insert;"UXO Surveys";\1;;$M=$(getvar,USERR1);setvar;USERR1;$M=$(+,$(getvar,USERR1),1); - to create a block (with a circle that has a 4m diameter)
I have tried adding in these macros to 2019 verision and the numbering one works fine but the macro that creates the blocks does not. Is there an alternative macro that I could use?
I use 4 meter diameter circles all day to mark up drawings and would be grateful if anyone could help. From what I understand it's just that this macro is not compatible anymore.
Any ideas/solutions would be greatly appreciated.
C
Hi all,
C
3 REPLIES 3
pendean
pendean
Community Legend
Community Legend
What part of the macro doesn't work exactly? Find out, CTRL+F2 and scroll up, read through it.
steven-g
steven-g
Hi Claire,
I'm not sure if anything changed but try this macro
*^C^C_-insert;"UXO Surveys";\1;;;$M=$(getvar,USERR1);setvar;USERR1;$M=$(+,$(getvar,USERR1),1)
It's not a big difference, just an extra ";" when you are inserting the block , this should work. Otherwise a copy of your command history when you try the macro's might show up the problem.
Hi Claire,
in reply to: steven-g
Thank you for your help :).
I somehow managed to rectify the issue - not sure what the problem was but it's all resolved.
C
C
Technology Administrators
