Creating a given radius circle, that passes through a point and is tangent to another circle.
armaangohil
Message 1 of 11
armaangohil
I am trying to create a circle, whose radius is given to me. I want that circle to pass through, a point and should be tangent to another circle.
Replies (10)
Message 2 of 11
RobDraw
You will need a third circle use the center of the circle you want to be tangent to with a radius equal to the distance of the point from the center. Draw the other circle tangent to the given circle anywhere. Then rotate it using the intersection of the circles that you want at the point.
Hope that makes sense.
Rob
Message 3 of 11
h_s_walker
See the image below
Howard Walker
Left Handed and Proud
Message 4 of 11
Washingtonn
Visual of what RobDraw said....
Message 5 of 11
armaangohil
Thank for recreating the visuals. An easier introduction for a new learner like me to the software.
Message 6 of 11
armaangohil
Thank you RobDraw for the solution.
Message 7 of 11
armaangohil
Thanks for replying a different visualization to problem.
Message 8 of 11
armaangohil
Only works if the radius(cr) = distance(point, outer circumference point of C) | Not a universal answer
Message 9 of 11
Washingtonn
There is no universal answer  - you specified a circle of known radius to pass through a point and be tangent to an unknown circle.
  For points inside the unknown circle -> anywhere provided that the known circle radius is equal to 1/2 the radius of the unknown circle. A larger or smaller known circle radius will reduce available tangent point placements.
  For points outside the unknown circle -> locations no more than twice the radius of the known circle away from the perimeter of the unknown circle. The circle cannot pass through points located beyond that distance and still be tangent to the unknown circle.
Message 10 of 11
RobDraw
Sure there are null solutions and a single radius that will hit the point only once but beyond that minimum, there are two possible solutions for every radius larger than the previously mentioned possibilities.
In the context of this thread, the given solution is quite easily proven.
Rob
Message 11 of 11
armaangohil
Finally, I tried it again. With the help of geometry, I was able to create the circle.
Condition for the radius of the circle to be drawn is as specified by you.
Creating 2 locus:
Circle of radius to the drawn, should be created with given point as center for the circle.
Difference in radius, given circle and the circle to be drawn. Center of the given radius circle.
The intersection point gives us the center point for the circle to be created. We already know the radius, and hence create the circle.
