AutoCAD LT Forum
Crash when going into UCS Manager after inserting view with custom UCS
2 REPLIES 2
397 Views, 2 Replies
We have a problem in my company - we are using the conventional  SSM setup.
Creating UCS's, naming them, then creating new views with the created UCS.
Through SSM we insert the view from the X-REF on our sheets.
After the view has been pasted, we want to go into model space of the sheet, change to the UCS that follow the view that was just inserted by going through UCS Manager and renaming the view. When we type UCS manager AutoCAD crashes.
There is a workaround, but I would still like to solve the problem.
If the sheet is saved after inserting the view, then closed and reopened, CAD will no crash and we can move on.
I have I been in contact with both AutoCAD support and Autodesk, but they have need been able to give a solution to the problem, so now I am trying crowd-sourcing.
/Kristoffer
2 REPLIES 2
pendean
Other than the workaround,what else have you all tried at the system level, drivers updates (or downgrades) and other LT system settings changes?
Do you "...sheet is saved after inserting the view..." before you try to enter modelspace and rename the UCS? Or just skip it?
Your exact LT versions as listed in ABOUT command?
Assuming Win10, what is the vernum?
Can you also post a screenshot of typical GRAPHICSCONFIG command pop-up?
in reply to: pendean
Though I attached a screencast to this post, but I guess something went wrong.
Technology Administrators
