AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Count dyanmic blocks in AutoCAD LT 2024
9 REPLIES 9
Message 1 of 10
laurencemulchrone
262 Views, 9 Replies
Having scoured the internet and these forums I am struggling with this question:
I wish to count instances/increments of a dynamic block and output the counts to a table. All solutions I have found involve the Data Extraction wizard, which is not supported in LT.
Has anyone found a solution to this?
9 REPLIES 9
Message 2 of 10
hwalker
in reply to: laurencemulchrone
@laurencemulchrone Use the COUNT command. See the link below. You can even create a table with it. See the image below
AutoCAD LT 2024 Help | COUNT (Command) | Autodesk
Howard Walker
Left Handed and Proud
Message 3 of 10
laurencemulchrone
in reply to: hwalker
Unless I am mistaken, the Count function will not work properly with dynamic blocks.
I have a dynamic block representing a plastic temporary road panel that repeats in 2.4m increments. The block has one linear parameter that defines the dynamic increment
I am trying to count the total number of temporary road panels. The Count function returns a value of 1 for each instance of the dynamic block, regardless of how many increments.
Hopefully that makes sense?
Message 4 of 10
cadffm
Try it and send feedback then 😉
Sebastian
Message 5 of 10
I have indeed tried it. I have double checked again, and as shown in this screenshot - the COUNT command returns "1" for the dynamic block in layer "Trackway" - which I have extended to 5 panels/increments
Message 6 of 10
hwalker
Do you need a table or do you want the number of panels to appear in the block?
Howard Walker
Message 7 of 10
laurencemulchrone
Thanks for your reply!
I need a table - i.e. a bill of quantities. I a completed drawing there will be potentially hundreds of instances of these Trackway panels each a separate element.
Hopefully you can see from my screenshot that I've already figured out how to show number of panels in each block.
It's the 'Grand Total' that's eluding me!
Message 8 of 10
pendean
Nothing in LT does what you need: sorry @laurencemulchrone
If this is a dire business need, you'll want a full AutoCAD subscription moving forward (no trade in as far as I know if you are thinking about asking), as you found out, and I'm not sure this LISP solution will work in LT2024-2025 either but you are welcome to try it
https://www.lee-mac.com/dynamicblockcounter.html
Message 9 of 10
cadffm
>>"a bill of quantities"
You can get what you have. In your sample is just ONE instance(Blockreference) and if I may guess: One Linear parameter with a length of 5 or another value.
Checkout blockreference properties, there is no "5", except your liniear parameter is 5 long.
>>"Hopefully you can see from my screenshot that I've already figured out how to show number of panels in each block."
Did you create this "5.00" field? Then you know it..  because you don't link to "5 Panels", your field linking to another property (like the value of linear parameter)
And you can add this property to the count result too
Rightclick here (red marked) and add your dyn.Block property you are after
Test it: Create a sample with 6 blockreferences, 3x one panel, 2x two Panel, 1x 3 Panel)
my sample attached
Sebastian
Message 10 of 10
cadffm
in reply to: pendean
COUNT can do this, also in LT
It works! But the tool is for dynamic visibility-property only (it would not work for Array-property)
Sebastian
Technology Administrators
