Copy layouts from 1 file to second file
meirbitXEY88
meirbitXEY88
I have file (1.dwg) that contain several layout's.
I copied parts of file 1.dwg (from model space) to file 2.dwg (by "copy with base point" option).
now I want to copy all the layout's from file 1 to file 2...
Is there an option like this?
thank in advanced
Meir
h_s_walker
Open up both drawings. Make sure you are in the drawing you want the layouts to be copied into.
At the command line type ADC which will open up DESIGNCENTER
Expand the tree of the drawing which has got your layouts in. Then just drag and drop the layouts into your current drawing.
See the image below. I'm in Drawing1 and the layouts I want to copy are from Drawing2.
Howard Walker
Left Handed and Proud
