You are going to have to SCALE one of the drawings
correctly: all you need is a known dimension in both plans
and have to know in advance which one you are going to draw
in.
You reference a plotted scale: all AutoCAD file content
should be drawn at 1:1, nothing else. So first thing you
want to do is to confirm this. Then you ask your engineer
what they used for a dimension of 1unit (is it one foot for
example).
Then assuming you are also drawing at 1:1, and your setting
is 1unit=1", then it's obvious by how much you need to scale
one of the drawings (1foot=12").
Now all you have to do is call up the Engineer that sent you
the file and ask.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
