Convert a polyline that has width to a polygon
Message 1 of 16
Is there a way in AutoCAD LT 2014 to convert a polyline that has width to a polygon?
Thanks.
Replies (15)
Message 2 of 16
pendean
Community Legend
Community Legend
A polygon is a uniform shape and in AutoCAD/LT it is made up of a PLINE.
Try it yourself, start POLYGON command, draw a shape, then start LIST: AutoCAD reports you selected a POLYLINE. PEDIT works on it to assign a width, so does PROPERTIES command.
Do you mean something else perhaps? Or do you have a picture of what you have vs. what you want?
Message 3 of 16
Sorry, I wasn't very clear. I was given a drawing that is made up of polyines of width. I would like to have the outline of the polyline be a polygon. Is that possible?
Message 4 of 16
pendean
Community Legend
Community Legend
Please post a picture of the problem and what you want the solution to be, your second post remains unclear. Sorry.
In AutoCAD... POLYLINEs are lines and POLYGONs are shapes made with lines,, and you can't turn lines into shapes with a command in AutoCAD.
Message 5 of 16
Message 6 of 16
pendean
Community Legend
Community Legend
POLYLINEs are lines: like string, you can have a thin piece of string or you can have a rink piece of string (like a rope)
POLYGONs are shapes: like a plate. No thin or thick string option unless you want to glue it on (draw a thick pline over the polygon and group them together which may add more problems).
What you are asking for is not an option in AutoCAD. You can't do it. Time to move on my friend 😉
Message 7 of 16
steven-g
A polygon by definition is straight sided, but from the look of what you have posted, you just want an outline of the polyline. There is no direct command or magic button for doing this, but as a workaround you could use the wmfout / wmfin commands, It will require a bit of work, because wmfin scales everything down, you will need to explode the inserted image (twice) and then do some manual tidying up, before using the pedit command to turn it all back into a polyline, or use the boundary command. Basically it takes a screen shot of the selected objects and inserts it back into the drawing as a series of outlines.
Start the wmfout command and select the objects you want, you will be asked to give a file name to save as, then start the wmfin command and pick the file you just saved, you will be asked for an insertion point, scale factors and rotation angle, I'll let you figure all that out. When you have the object inseted explode it all twice and you will see what needs editing.
Message 8 of 16
I came upon this thread looking for the same answer. I see there is no answer here, but I found it on another thread
I know it's a couple years late, but if anyone needs the answer, use FLATTEN command to change PLines with thickness into a PLine that OUTLINES this thickness.
FLATTEN, the choose YES.
Message 9 of 16
pendean
Community Legend
Community Legend
FYI there was no FLATTEN command in the LT version of AutoCAD back in the year 2015 https://forums.autodesk.com/t5/autocad-lt-forum/flatten-command-in-autocad-lt/td-p/6619106
Message 10 of 16
If it didn't exist, say it can't be done. Simple.
Message 11 of 16
cadffm
@Anonymous
"I came upon this thread looking for the same answer. I see there is no answer here, "
That's wrong, you answered direct under the answer&solution in #7 from Steven !
And your answer is wrong because, as pendean wrote, flatten is not available in this software, also not in 2021.
You are talking about another software that doesn't help in this case. What you said: If it didn't exist, say it can't be done. Simple.
As first it was just unsure what OP have and what he want, that's usual. After clarification the  answer was:
"What you are asking for is not an option in AutoCAD. You can't do it. Time to move on my friend"
What isn't wrong. Stevens way is a workaround to reach the goal, but there is no command to do it perfectly in one step.😉
Oh, 12:37 am, time to sleep
Sebastian
Message 12 of 16
jrogulski
Message 13 of 16
steven-g
@jrogulski No there is no LISP in LT, none of the programming API's are available to LT users.
Message 14 of 16
federico.ringeling
Community Visitor
Community Visitor
Thank you sooo much
Message 15 of 16
federico.ringeling
Community Visitor
Community Visitor
Thank youuuuuuuuuu!!!!
Message 16 of 16
mattmanuel046
Community Visitor
Community Visitor
You are my hero. I am using ZWCAD and this solved my problem perfectly. Thank you!
