control / paste blocks with attribute info not displaying
renrave
renrave
Anyone come across issue of copy / pasting blocks with attribute info, where when you paste it the attribute info does not show? Found ANNOALLVISIBLE variable was set to 0, changed it to 1 and copy/paste worked as expected. But for some reason, this variable keeps reverting back to 0. Anyone else come across this issue?
paullimapa
there must be something else that's causing that variable to revert back...it does not do it by itself
Paul Li
IT Specialist
@The Office
renrave
Yes, correct, variables should not change unintentionally. Was hoping someone was having same issue
pendean
Community Legend
Community Legend
How do you know it reset: what is your discovery method exactly?
Where do you store your DWG files exactly?
That's a per-dwg level variable setting @renrave
Are you by chance manually saving your DWG file soon after changing it to 1? That would set it for sure and make it stick for all of us. Find out. Test it for sure.
If you set that variable to your desired setting in SYSVARMONITOR command, it will alert you exactly when it changed and might help you catch the culprit.
