Content Explorer
Content Explorer
Content Explorer
Content Explorer
Content Explorer is an add-in that is shared across Autodesk products. It enables you to search for design content in locations you specify for monitoring. Search is performed quickly thanks to indexing. From your program, use Content Explorer to:
Browse for content in local folders, network folders, and the Autodesk Seek Library.
Browse inside DWG files and access blocks, layers, linetypes, styles, and so on.
Search for objects, text, and attributes (including block attributes).
Save search parameters for easy reuse.
Customize how search results are displayed.
Insert content from search results into your current project, or a new project.
I have AutoCAD Light 2015
Use it mainly for printing our company old dwg etc.
The file names of most of the dwg files is short names
In the Block Reference of the title block are INFO that will help us
See attached picture
NO give drawing number
TTL1 give drawing description
Ect ect
How do you setup Content Explorer to show this content and / or see it directly in Windows 7
pendean
Community Legend
Community Legend
