Command options when we select an object
cb94030
cb94030
I have ACAD LT 2023 subscription.
How can I activate the menu when clicking an object, like a line, etc, and see the command options available for that particular object?
Thank you in advance!!
Chris
paullimapa
make sure GRIPS is set as 2
then when you select a line you'll see blue grips appear
select any one of the blue grips & you'll see additional options on the command line
Paul Li
IT Specialist
@The Office
cb94030
Thank you paulli_apa for your help.
I was trying different things and I figured out that it is in:
Options>User Preferences>Windows Standard Behavior, then checked here, "Shortcut menus in drawing area".
