AutoCAD LT Forum
Command line window will not dock
22 REPLIES 22
Message 1 of 23
18702 Views, 22 Replies
The command line window moved from the default location at the bottom of the screen to a floating position while I was working on a drawing yesterday. I don't know what I did but can't move or resize to get it back down to the bottom where it belongs. I can get it to dock to the left and right or float but nothing else. It doesn't behave like the the other palettes n that I can't seem to drag it anywhere. Am I missing something or is it a glitch?
Thanks for any help you can give me.
22 REPLIES 22
Message 21 of 23
steven-g
Understood, but Ctrl+9 only turns the command line on or off it won't dock it which is what the OP asked about. If it is floating then it remains floating when you use Ctrl+9
Message 22 of 23
in reply to: steven-g
I had a floating text window which (to me) looked quite a lot like my normal command line, but it was not dockable.
(which led me to this site/page).
If it happened to me, it will probably happen to others, hence my initial post.
I appreciate the replies/help, but i only wanted to post my own solution that i found elsewhere.
Message 23 of 23
christineLXA6M
thanks so much for posting that !
Technology Administrators
