Dwg is attached.
I NOT WANT MIXED COLORS (DISPLAY SEE)
-I did bring it to the front(GREY COLOR), but it doesn't work.
THANKS YOU.
I wait... 🙂
Solved by cadffm. Go to Solution.
Okay,
there is nothing wrong, that's a normal "behavior".
I guess this started with 2015 versions (if anybody can test it with 2014 and 2015 - please test it),
in 2015 Autodesk changed a core thing about how the program display data on your screen.
in 2013 your file looks as expected! I guess in 2014 too and in 2015 not (but I can't test it).
I draw on my side in my own file new lines, also with Color1 and Color8 like your sample = same result!
hmmmpf
your file 'small_family_house.dwg' in 2013. Same Computer, same Monitor.
Sebastian
