color issue
color issue
color issue
hello
i am having issues with colors in my modelspace and plotspace all colors show as a shade of blue color but when i print something it prints in right color.
any solutions please im using autocad LT
If you see different color between printing and model,
Check your Plot CTB, Layer status (Whether ByLayer or Color), Block object (It needs to see in Block editor).
Victoria.Studley
Hi @Anonymous,
Welcome to the Autodesk Community!
  • Could you post a quick screencast or a screenshot to show us what's happening?
  • If the issue is specific to one file, could you post a copy of it here for us to analyze?
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
i have figured out why it is happening so when i have autocad runnig on amd graphic cardit it cannot process colors properly it turns every color to a shade of blue but it works ok on integrated graphics. is there good solution to fix that.Capture.JPG im using Graphics Chipset
AMD Radeon(TM) HD8970M
Victoria.Studley
Hi @Anonymous,
Thank you for posting the screenshot and additional details.
It looks like your AMD card is not certified for AutoCAD 2018 products on Windows 7, 8.1, or 10 systems (you didn't say which you're working on, so I'm included both as examples).
This means that, while you may be able to get the card to work well, it is not tested or guaranteed by Autodesk to work well.
There are a couple of options for you to try to work around this:
  • Install the latest driver available for your card from AMD, since the newer drivers tend to improve upon the older ones.
  • Disable Hardware Acceleration, since this takes advantage of the features in the certified cards.
  • Upgrade to a certified graphics card.
Victoria Studley
