CLIP command
CLIP command
chick.biker
Message 1 of 12
CLIP command
chick.biker
I know I know, Autodesk does not support the 2013 version.  Very frustrating, given the cost of this software.
I have a problem with the CLIP command.  I have used it one other time without issue.  I am having sentimental thoughts about my days using Microstation, in which clipping a reference file was so easy and worked much better!
What's happening is that when I select the boundary to clip the xref, it inverts the clip - so that everything OUTSIDE the clipping boundary is clipped, not INSIDE.  I have no idea why!  Can someone advise?  Is there a clip setting that makes the command default to inverting the clip???
Chick.biker
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
You are probably doing this https://autocadtips1.com/2012/04/11/invert-xclip/
Be careful.
Message 3 of 12
chick.biker
Be careful is not super helpful, and that is not what I did.
I cannot find anywhere in ACAD LT 2013 where the xref dialogue box has a command option.  So here is what I did:
In model space,
RECTANG
Created a rectangle on defpoints to use as a clipping boundary
CLIP
Clicked on the xref to select
New (default)
Selected the rectangle as the new polyline
This clips everything outside the polyline instead of inside.
Chick.biker
Message 4 of 12
pendean
Community Legend
Community Legend
Thanks for coming back: what you describe does not invert the XREF here.
What portion of the XREF are you selecting? Is this an xref that is already clipped?
Show m a video of your screen with this problem in action?
Is this a sudden new problem that never appeared before in LT2013?
Or a problem with one file or one xref?
Windows OS is what?
What else may have changed on your PC?
Message 5 of 12
chick.biker
I just clicked on the xref on the screen in model space to select it - I did not select a portion of it, just clicked on it randomly.  The xref is not already clipped.  I have only used the clip command once before in Autocad - I have LT 2013.  Nothing else changed on my computer.  I'm not sure how to do a video of my screen!
Chick.biker
Message 6 of 12
edwin.prakoso
Can you upload the files (host and reference files) so we can take a look?
Just to be clear, you did this before and things work well?
Cheers,
Edwin Prakoso
Message 7 of 12
edwin.prakoso
I think I know where the option is. You made the boundary from existing polyline, that's why you don't see the flip arrow.
However, when you create the xclip you can invert the boundary. After you click New, there is the Invert Clip option. You probably chose it when you create it.
See the command line below:
Outside mode - Objects outside boundary will be hidden.   <--- Before invert
Specify clipping boundary or select invert option:
[Select polyline/Polygonal/Rectangular/Invert clip] <Rectangular>: i
Inside mode - Objects inside boundary will be hidden.        <--- after invert
To fix it, you can recreate the xclip. Make sure it says "Outside mode - Objects outside boundary will be hidden." before you select the rectangle
Cheers,
Edwin Prakoso
Message 8 of 12
chick.biker
Are you saying that default mode is that objects OUTSIDE the boundary are hidden?  I thought it was the reverse.
Chick.biker
Message 9 of 12
edwin.prakoso
Yes, the default is OUTSIDE boundary. In AutoCAD 2018, the setting is not saved after you use the command. The default is still outside. However, I can't confirm the same behavior for AutoCAD 2013. The setting is probably saved or the polyline direction probably affects it.
Cheers,
Edwin Prakoso
Message 10 of 12
chick.biker
I thought the inverse was true, and I thought that was what happened the first time I used the command.  But if the default is outside the boundary, then it's working correctly and I need to invert it.  I will try and accept this as a solution if it works.  Probably tomorrow morning, though, I am working on paving details.  Thank you!
Chick.biker
Message 11 of 12
steven-g
Default is outside, another you might need to check is that the existing polyline you used isn't "above" the clipped object as far as draw order is concerned,
it could be that if you click on the boundary of the clipped object, that it is the polyline that highlights, and that won't show the blue inverse arrow.
Message 12 of 12
Emmsleys
Hi @chick.biker
Checking in, were you able to find a solution? Or a workaround?
Did any of the posts in the thread help with your issue?
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
