AutoCAD LT Error Aborting 2018
I recently installed AutoCAD 2018 on my machine and was working on it until I started receiving this error message:
"FATAL ERROR: Unhandled Access Violation Reading 0x78b50748 Exception at 7729f23ch"
This usually happens when I try to save or export to PDF. It also happens at random times while the program is open.
Would this have anything to do with my current machine hardware?
My current machine is a HP EliteBook 850 G2.
Graphics card: Intel HD 5500
Thank you for the support!
pendean
Community Legend
Community Legend
Do you have the 2018 patch installed yet?
Note that there is no universal fix for "... also happens at random times..." so you might have to try many things to find a solution.
Thank you. I will try patching and see if the issue still occurs.
Emmsleys
@ txiongLA55W,
Looks like you're a new member to the community, WELCOME!
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Or post with any new updates if you need continued help on your thread.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
Hello, yes I had to re-install AutoCAD and now it is working again. Thank you.
