Is there a solution, other than annotation scaling, to change multiple annotation settings at the same time? In other words, when I switch scales of annotation (text, dimensions & leaders) it takes 3 separate actions (changing text scale, changing dimension scale, changing leader scale). I think the autocad solution for this issue is to use annotative scaling, but it really clutters my drawing & I don't like using it. Is there a way to group the all the settings for a particular scale together so that switching back and forth involves one command rather than 3?
Solved by pendean. Go to Solution.
I don't use Annotative objects, but if you select all 3 and then check the Properties (Ctrl+1) Does the Annotation scale show there?
Howard Walker
Thanks for the thoughtful reply, Dean. I think yes, it might be time to teach the old dog a new trick (that's not so new to everyone else!) Is there a resource you would suggest for a quick summary of going the annotative object scaling direction? I've used them in the past when working with other peoples drawings. Main thing I don't like is the autocad feature of hovering over the annotation and then all of the scales become visible. Maybe there's just a simple way of turning off that feature?
Thanks again,
Alan
Dear sir Please find the Below Attachment..that is my problem ...please make it early as possible.
Hi, please read the accepted solution. I think his response addresses what you show in your attachment. I think it has to do with the setting of ANNOALLVISIBLE
