@gerdaC5X5X wrote:
I am trying to Rotate a View by Changing the UCS: https://help.autodesk.com/view/ACDLT/2024/ENU/?guid=GUID-64EB33A4-945A-4548-AC59-A4C597A41FF9
To Rotate a View by Changing the UCS using typed commands to minimize distractions from pretty icons on the Ribbon:
1) turn on UCSICON.
2) Double-click within the unlocked viewport whose objects you want to rotate.
3) Make sure that the current UCS is parallel to the plane of rotation (the UCS icon should look normal).
3) Start UCS command, type Z, then type 45 (45 degree angle for this excercise).
4) Start PLAN command, choose CURRENT UCS.
5) The entire view rotates within the viewport. You may need to specify the scale of the viewport again. You may now LOCK the viewport. Modelspace stays the same if you already had UCS set to WORLD over there. UCSFOLLOW is always off here.
See attached. Done in LT2024.
