I want to set up a dimension for use as a standard for our office. I like the architectural tick marks to be darker than the other lines. I have searched the dimension style properties and can not find a way to do this. I have a dimension from a past job that shows this customization. I can't figure out how they did it. Any help with this type of customizing?
Thanks in advance!
Solved by pendean. Go to Solution.
Circling back on this thread, were you able to try the suggested steps.
Please post back in the thread if you are still having an issue with AutoCAD the community and myself will be more than happy to help.
