centring floor plan
centring floor plan
daniel_dysonAGX6U
centring floor plan
daniel_dysonAGX6U
When it comes to exporting to PDF the header is no longer positioned correctly?
Im sure its some type of margin in play here but i can figure it out. Happens on the right side only.
AutoCAD
After exporting to PDF
pendean
Community Legend
Community Legend
@daniel_dysonAGX6U Your 'what to plot' or 'page size' changed or it is not what you want in your settings for "export to pdf" and PLOT commands: since you are in total control, have you tried fixing there issue in PLOT and PAGESETUP commands yet? PREVIEW command is often a good way to preview what you might get.
paullimapa
Does this only happen with the Export pdf option or also when you plot to pdf? Can you share a sample dwg here?
Paul Li
IT Specialist
@The Office
