Cannot upload picture using IO. Failed to create object. Make sure the object is entered in the system registry.
v.juustas
v.juustas
Hello everyone,
Reacently i have updated to Windows 11 and imediatly after the update, when i try to insert a picture into AutoCad LT drawing i get this errror: Failed to create object. Make sure the object is entered in the system registry.
I upload pictures (stamps, signatures and etc.) using commcand IO (Insert Object > Paintbrush Picture) because I need those pictures to stay on file and its the fastest way to do that.
cadffm
>>" i have updated to Windows 11"
First question: W H Y ?
Sebastian
v.juustas
Because i wanted to. Thanks for answer
cadffm
Without needs, that is a really bad step, but your choice.
You "updated" from win10 to win11 or set up a new operating system from scratch (format / install win 11?)
If "Updated" : Autodesk recommends to deinstall products, update all drivers for the newest, then install Adesk products).
But we know about more than one graphic issue with Win11 and on system reqirement list for 2022 products,
win11 still not listed (the only small hint from Adesk about win11 is a short AKN page https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Will-A...
And like it is with all software and all OS: Compatible doesn't mean it works with all hardware and drivers without errors.
I keep my fingers crossed that you get it under control with a clean installtion after driver updates,
but I personally have little hope.
Sebastian
pendean
Community Legend
Community Legend
