Cannot print photo PASTESPEC
I am running AutoCad LT 2018
I have been trying for some time to insert jpg's, png etc into a series of drawings. I have used the pastespec command with Paintbrush Picture, Picture, Devices Independent Bitmap and Image Entity. The photo's appear in the drawing The trouble comes with plotting to either pdf or my printer  when the image just disappears??
Patchy
The layer the photo resides is set to no plot or on defpoints?
pendean
Community Legend
Community Legend
... or the plot output is too large for the drivers you are aiming for.
Thanks for the suggestion but the layer is set for plotting.
Regards
Alan
Hi
The I have manged to insert photos in the past but it has always been a bit patchy. This current session I have tried almost everything that has been suggested and now the only way I can get around it is by inserting it as Raster image ref. The only problem with this is that when I send my drawings over we need to sort out the links?
Alan
h_s_walker
Why not use IMAGEATTACH to insert the images (always put them in the same directory as the drawing)?
If sending the drawing out why not use ETRANSMIT? This creates a zip file with all relevant files needed to open the drawing.
Howard Walker
Left Handed and Proud
hwalker
I have just tried out your suggestion and it has worked a treat.
Alan
