Cannot paste properly into a particular file
 I am recently working on consolidating a drawing with blocks/drawings from multiple sources. I have run into the following problems which seem file-specific and need help to resolve them.
(1) Random crosshairs (circles with crosses) appearing on objects after I put them into the consolidated drawing. When I perform certain operations like MOVE or cut/paste, the crosshairs enlarge or become smaller. These crosshairs are actual objects which I can delete but they are never supposed to be there in the first place. REGENALL also reduces the size of the crosshair to a small size.
(2) Cannot paste blocks/items properly. Only part of what I copied from another drawing would be pasted successfully. I tried pasting the same thing into a new document and it works perfectly.
Things I've tried:
- AUDIT
- REGENALL
- PURGE
I read something about restoring the system variables but I have not been able to get the steps for that so I am not sure if that will help.
Some advice is much appreciated!
Erense
The first 'crosshairs' you are talking about sound like 'points' to me. You say you can select and delete them. What type of object is it when selected (see properties).
Try changing the PDMODE value
You may try an AECTOACAD for the 'destination' drawing for the copy/paste error.
It's kind of hard to say about both. Screenshots or attachments like the DWG could help us to help.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
Emmsleys
@Anonymous,
Following up on your thread, if time allow it are you allowed to provide more information? Like screenshots and or drawing files.
Sarah Emmsley
Technical Support Specialist
john.vellek
Hi @Anonymous,
Are you still having problems with the one file? Is it possible to attach it to a post or send to me (private) at [email protected]?
I would suggest rebuilding it by moving it into a new file.
John Vellek
john.vellek
HI @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
