I use colors 250 - 255 in all my drawings, and already have all my layers set up with these colors. However, I often need to access these colors instead of relying on ByLayer or ByBlock. Is there a way to keep these colors on my properties palette without having to manually open them via the "More Colors" tab every time I open AutoCAD?
Solved by cadffm. Go to Solution.
"No way" but one small workaround
Write a macro or lisp like this
_.CECOLOR;250;_.CECOLOR;251;
and so on, at last set ByLayer current.
After this steps the colors should offered in your color lists.
Sebastian
