AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
can not extract specific attributes in CDF file
2 REPLIES 2
nosurvive
264 Views, 2 Replies
Hi there,
I’ve recently faced a technical issue about the command ATTEXT, which is related to attribute extraction.
I extracted a dwg files by an attribute extraction template file- they are the attached files-. I had the values in P_Survey and P_Finished fields ,etc. However, I failed to retrieve them in my output CDF file but I succeeded in the P_NAME attribute and the block layer.
I don’t know why and can using Chinese characters in the value of P_PLACE a be possible cause ?
Thanks for your answer in advance.
ref :
the block attributes
the resulting CDF File
2 REPLIES 2
cadffm
in reply to: nosurvive
>>"can using Chinese characters in the value of P_PLACE a be possible cause ?"
Change it, try it and you have the answer to this question. Chinese characters are in other attributes only, so it isn't a problem here.
>>"I don’t know why "
The Problem are your attribut tags. In old AutoCAD days it was a rule that you have to use uppercase characters only,
that's also the reason why Acad changes your lowercase characters to uppercase for ATTDEF and TEXTEDIT command!
But unfortunately new tools came along for editing which no longer implemented this requirement, such as: The properties palette,
Not to mention thousands not licensed by Autodesk .DWG/.DXF interfaces.
It's just stupid that the dinosaur function "ATTEXT" still expects capital letters in the .dwg/.dwg.
There hasn't been time to revise this matter in the last 30-40 years.
Solution: Edit your block(s)
Select one reference, BEDIT, doubleclick Attdef with lowercase characters, close the textedit dialog
do it foreach Attdef with lowercase characters, bsave, bclose
And update your blockreferences by Attsync.
Now it should works!
(no need, but looks cleaner, change the lowercharacters in attext mask file too)
Sebastian
nosurvive
Thank you very much and it really works just as you said 🙂
Technology Administrators
