Can I retrieve an Over written Drawing?
robdi233
Observer Observer
robdi233
Observer
Observer
Hi
Need to Retrieve an older drawing.  Does autocad save drawings automatically? and how can I view these saved drawings?
h_s_walker
If you can't find a .sv$ file in C:\Users\%yourusername%\AppData\Local\Temp which is the default area it saves temp files then I believe you won't be able to.
Howard Walker
Left Handed and Proud
RobDraw
The first file to check is the .bak file that is in the same folder as your file. It is the same file that was saved previously. Change the extension to .dwg in order to open it.
Rob
pendean
Community Legend
Community Legend
Brock_Olly
If your computer/server uses windows backup you could rightclick the folder your drawing is in and click "Restore previous versions" to find your old drawing
