AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
CAMBIO AUTOMATICO DEL CURSOR SOBRE IMAGEN
6 REPLIES 6
489 Views, 6 Replies
HOLA A TODOS.
EN AUTOCAD 2009 VERSION COMPLETA, CUANDO PASAS EL CURSOR SOBRE UNA IMAGEN, ESTE CAMBIA DE COLOR AUTOMATICAMENTE, SEGÚN SEA EL COLOR DEL FONDO DE LA IMAGEN, PARA QUE RESALTASE PERFECTAMENTE EL COLOR DEL CURSOR SOBRE DICHA IMAGEN.
¿EXISTE ALGUNA MANERA DE PODER HACER ESTO EN AUTOCAD 2016 LT?
ADJUNTO CAPTURA DE PANTALLA DE AMBOS CASOS.
MUCHAS GRACIAS
HELLO EVERYBODY.
IN AUTOCAD 2009 VERSION COMPLETE, WHEN YOU SPEND THE CURSOR ON AN IMAGE, THIS ONE CHANGES COLOR AUTOMATICALLY, AS IT IS THE COLOR OF THE FUND OF THE IMAGE, SO THAT IT WAS HIGHLIGHTING PERFECTLY THE COLOR OF THE CURSOR ON THE ABOVE MENTIONED IMAGE.
DOES EXIST ANY WAY OF BEING ABLE TO DO THIS IN AUTOCAD 2016 LT?
I ENCLOSE SCREENSHOT OF BOTH CASES
THANK YOU VERY MUCH
6 REPLIES 6
pendean
It looks like you change the colors on screen items in LT2016 manually instead of using the default colors, correct? If yes, what colors did you choose for cursor and backgrounds?
in reply to: pendean
Hello. The colors are the same that initial configuration. Black for background, and white for cursor
Must be an option to change automatically the color of the cursor, that I can't see !!!
Alejandro Benito
Enviado desde mi iPhone
pendean
As far as I know you can't change the behavior of LT2016's cursor: it's tied to contracting the background color only now
Settings colours are the initial configuration. Background is black. Cursor is white....
So, if i can't change this, don't understand that 2016 version can't make things, that olders version can !!
Its very dificult draw over a image with white background, having a white cursor....
The only thing that i can do, its click in the place that i mark in the attached
Thank you all
pendean
Agreed.
Log into your subscription management page, select the SUPPORT link at the top, middle option, start a support ticket and ask Autodesk to fix it if they can.
Technology Administrators
