block is scaled when inserting it in a new Layout
Hello to all of you,
I have a block which was created to be used as a title block, also only for layout. The block contains lines, text, attributes and two images.
When I try to insert the block in my drawing, only the lines are unexpectedly scaled up to x25. The image stays at its original size, as well as the attributes. I am trying to copy from Layout to Layout, also units are the same, milimeters.
I have also tried to import the layout through the Design Center, but it comes exactly to the same problem.
If it helps, If I explode the block and try to copy its original content from one file to the other, it is the right size. What might be happenning? Has someone any idea that could help me?
I have searched for articles, I found these: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Blocks...
But it didn´t work. All units are exactly the same on both drawings.
Thank you very much in advance! Any help will be gladly appreciated.
Best regards
