AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Block creation default properties
4 REPLIES 4
amin
217 Views, 4 Replies
Since version 2023 (if I remember right), the default properties for newly created blocks changed from "Allow exploding? Yes" to "Allow exploding? No".  Is there a way to change it back to the way it used to be, to allow exploding?
If the answer is no, then is there a way to force-explode blocks without going through the tedious steps of changing the properties one at a time?
4 REPLIES 4
paullimapa
in reply to: amin
not sure if that's true with LT but in AutoCAD 2024 when I enter the BLOCK command the default to Allow exploding blocks is automatically checked:
Paul Li
IT Specialist
@The Office
pendean
in reply to: amin
cadffm
in reply to: amin
Hi amin,
there is no "default" setting, not in 2023 and not in earlier versions (except the "default" setting of a new install or a new profile),
the settings of this dialog is saved in your Profile and should open the same like you used it at last.
Please set to to "Allow exploding?" - Yes, create one block.
Close Acad
Start Acad, start BLOCK command and check the setting.
Is "Allow exploding?" set to No?
In this case it is't a standard AutoCAD issue and I think that you have a lot more trouble than you currently know.
Sebastian
cadffm
in reply to: amin
>>"is there a way to force-explode blocks without going through the tedious steps of changing the properties one at a time?"
Since Autocad LT have LISP API, sure. So in LT2024 = Yes, in LT2023 = No
You will find tools to change one or all block to explodeable-yes, search for it.
Sample google hit: https://www.theswamp.org/index.php?topic=41980.0
Sebastian
Technology Administrators
