- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello all,
This may be a long-shot and one for the CAD guru's out there and any assistance would be greatly appreciated.
Background - I am working on multple civil earthworks plans that depict cut and fill set-out data. So far I have started labelling these with a use of a label block that has attributes - which i fill in as i place the blocks. See attached screen dump. N for natural surface, F for final design surface and a value "X" which is the difference of the two - which is either going to be +ve or -ve depending on whether its in cut of fill.
Issue - seeing as there are so many points to label, i would liike to 'automate' the "X" similar to excel where it will give me the answer as opposed to calculating and tryping them in manually.
Hope that made sense and i look forward to receiving any ideas.
Cheers!
GT
Adelaide - SA
Australia
