AutoCAD LT Forum
Black & White using DWG To PDF.PC3
8 REPLIES 8
Message 1 of 9
3383 Views, 8 Replies
Is it possible to plot in black and white using the DWG to PDF.pc3?
8 REPLIES 8
Message 2 of 9
h_s_walker
Change the plot style table from NONE to MONOCHROME
Howard Walker
Left Handed and Proud
Message 3 of 9
in reply to: h_s_walker
I just use mono but it print the same. colored
Message 4 of 9
pendean
The colors may be RGB or CMYK: those do not follow CTB plot style tables settings.
Do you want to go through the trouble of converting your DWG file into STB format and learn all about applying SB styles to objects and layers?
Or do you just want to quickly change all layers/object to color 7, print an call it a day?
Message 5 of 9
in reply to: pendean
I'm doing batch plot. I like the way when your done plotting all the sheets are in one file. but i want it to be in grayscale not colored. my drawing has colored image. Thanks
Message 6 of 9
pendean
Can you confirm the object colors and layer colors in your file(s) are RGB or CMYK first? Or post a portion of a DWG file here.
TIA
Message 7 of 9
How will I do that? anyway I'm attaching part of my drawing. and let me know. thank you so much
Message 8 of 9
pendean
Thanks for the file: MONOCHROME.CTB works just fine in your file here for me
Has yours been edited?
Message 9 of 9
Thanks, I now understand. Ole object and raster won't get gray scale so I will just convert them to gray scale before embed them to drawing. thanks man
Technology Administrators
