I have just installed autocad lt 2017 and I am trying to edit a block with attributes created in a different version. When I type in the command BATTMAN I get a message 'Unknown Command'. having tried this on a 2015 version there is no problem. Can anyone suggest how I get the command working?
Thanks for the prompt response. I didn't use the migration feature and this was a clean install. I did however try looking for a patch and found update SP1 which was issued some time before I installed this version. having run the patch the command is now working so either I wasn't up to date or this has just repaired the previous version. Strangely enough if I select help on the toolbar then the bottom option on the list says 'About AutoCAD LT 2015'. Further more if I select this option I get a screen which has copyright 2016 Autodesk, Inc
kind regards
Andrew
