Bad linetype definition
mr1471
Message 1 of 17
mr1471
Hi. I'm using Autocad 2012 and there is an error about linetype. BATTING linetype is showing as a question mark line and when I try to load the linetypes, error message('Bad definition of BATTING at line 122 ...') comes up.
The computer of others also have same problem.
From reading other posts I've got some solutions and did all I can do. (1. Check out acad.lin and acadiso.lin file. → And there wasn't different part between correct definition and mine. / 2. Check out a path of *.lin file and .shx file. / 3. Open a template as a acad.dwt. / 4. Overwrite *.lin file and ltypeshp.shx file. / 5. Reinstall Autocad.)
But they have only fixed a newly drawed dwg.
How can I fix it?
Thanks in advance.
Replies (16)
Message 2 of 17
h_s_walker
The below is the batting definition from my acadltiso.lin file
*BATTING,Batting SSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS
A,.00254,-2.54,[BAT,ltypeshp.shx,x=-2.54,s=2.54],-5.08,[BAT,ltypeshp.shx,r=180,x=2.54,s=2.54],-2.54
 The below is the batting definition from my acadlt.lin file
A,.0001,-.1,[BAT,ltypeshp.shx,x=-.1,s=.1],-.2,[BAT,ltypeshp.shx,r=180,x=.1,s=.1],-.1
Check to see if your two are the same and make sure there are no spaces at the end of the definition lines
Howard Walker
Left Handed and Proud
Message 3 of 17
mr1471
Sorry for my late reply.
I checked my codes and there were no spaces at the end of them.
Here is the code that I have.
[acadltiso.lin]
[acadlt.lin]
FYI, there is an external reference with the drawings which have the problem and other company made it.
I wonder if the drawing should be fixed by a person who made the drawing first.
Message 4 of 17
h_s_walker
Ok, so looking at your linetype definitions they are exactly the same as mine.
As to  your suggestion that the xref could be the problem do the following.
Create a blank drawing. At the command line type RECOVER. Now choose the xref and see if it fixes the problem.
Howard Walker
Message 5 of 17
steven-g
You do mention having checked the file location, linetype.shx file should be at
C:\Users\UserName\AppData\Roaming\Autodesk\AutoCAD LT 2021\R27\enu\Support
Can you confirm that is where it is, and if so then it might be an idea to post a copy of that file here, it sounds like you either don't have the correct file showing up in the support path
or the file itself is corrupted.
Message 6 of 17
pendean
Community Legend
Community Legend
>>>...But they have only fixed a newly drawed dwg. ...<<<
Is the problem in ALL of your files, even new ones, or just this one DWG file? I'm not clear on your statement above.
Message 7 of 17
mr1471
Here is the location of my linetypeshp.shx file.
C:\Users\thePYS\AppData\Roaming\Autodesk\AutoCAD LT 2019\R25\kor\Support
And I attach the file.
Message 8 of 17
mr1471
It means that the 5 solutions I had done fixed the problem in new ones. But they didn't fix existing DWG files.
Message 9 of 17
mr1471
I can't figure out how to do RECOVER at the command linetype.
Should I click some button at the command?
If so, could you let me know what button is?
Message 10 of 17
steven-g
That makes a bit more sense, the old drawings won't magically be fixed when after you have found the problem. You might have to reload the linetype again into those drawings and possibly even change the existing lines (in properties) from batting to something else and then back to batting before the lines will be corrected. In the worst case possible even redraw those lines, but that is difficult to say without seeing your drawing file. If trying those couple of approaches don't help then can you post a dwg with the problem lines?
Message 11 of 17
h_s_walker
I said at the command line type RECOVER. See the image below
Howard Walker
Message 12 of 17
pendean
Community Legend
Community Legend
INSERT your problem file into one of your perfect template files with all the linetypes preloaded, EXPLODE it, then SAVEAS to create a new file: test it, does the problem go away?
And since you asked, here is how to use RECOVER command https://autocadtips1.com/2012/10/17/recover-a-drawing/
Message 13 of 17
mr1471
I typed it, but it didn't fix the problem. I'd rather give up fixing it.
Thanks for every advice you've given to me.
Have a nice day 🙂
Message 14 of 17
mr1471
It doesn't go away. I think I can't fix it, so I'd rather give up fixing this problem.
Thanks for your advice.
Have a nice day 🙂
Message 15 of 17
steven-g
You can still post one of the old drawings with the problem linetype so we can see if someone here can see what the problem is, we only need that part of the drawing that shows the line with an error.
Message 16 of 17
mr1471
Should I post the dwg file? Is it okay if i post a image file?
Message 17 of 17
steven-g
An image won't show the problem settings we need a dwg file showing the error in the linetype
