I have some old AutoSketch files I need to convert to autoCAD. The old files are in *.igr format. I need a tool to do so. Any ideas?
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD LT forum. Welcome to the Autodesk Community!
How many of these files do you need converted? I can hunt around the office to see if anyone has a legacy install of this to convert one or two. Otherwise, the Suggestion by @rkmcswain is a good one. If you can share one of the files on a post I will see if I have any other tools or applications that will allow an import/conversion.
Hi @Anonymous,
I am checking back to see if my post or @rkmcswain's helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
