AutoCAD LT Forum
Automatic Sequential Numbering
6 REPLIES 6
davelomas
344 Views, 6 Replies
Hi I'm looking for macro that I can start to run that will allow me to number numerous units sequentially. Currently we use the text command and repeat. An example is in the picture attached where I typed C1, then C2 etc.
I've had a look on this forum as well as things across the web but cant get any to work:
https://cadingandcoding.blogspot.com/2007/08/auto-increment-numbering-macro-for.html
https://forums.autodesk.com/t5/autocad-lt-forum/autonumbering-autocad-lt-2018/td-p/7605962
https://forums.autodesk.com/t5/autocad-lt-forum/automatic-sequential-numbers-in-lt/td-p/7604089#:~:t....
If it helps, I'm using Autocad LT 2023. Could anyone please help me write a macro? Preferably with the capability to have a letter before each number like you can see in the picture I attached.
6 REPLIES 6
pendean
in reply to: davelomas
You'll want to upgrade to LT2024 (free with subscriptions) then you'll be able to explore the wider word of LISP customization to do what you want (LT2023 and older has no real elegant not-clunky not-difficult not-prone-to-hiccups permanent solutions you've already found).
davelomas
in reply to: pendean
That's annoying! Hopefully we can get 2024 because there's some Lee Mac Lisps that would also be extremely useful!
pendean
I have tested  few Lee Mac lisps and so far quite a few of them work like a charm.
The LISP Customization forum is also a good place to go searching for unique lisp routines that you might find very useful too, explore once you get your hands on LT2024 https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
davelomas
Thanks for the heads up. The main Lee Mac LISP that would save us a lot of time is the bounding box LISP as we often have curved units and need to determine the minimum amount of material required which can be quite time consuming if you have 50 bespoke pieces!
pendean
That one works beautifully in LT2024
Michiel.Valcke
Once you have version 2024, you might want to try out these lisps:
https://blog.draftsperson.net/numbering-lisp-routine-collection/
Technology Administrators
