Is there possibility to have Finnish language pack in Autocad LT 2016?
Solved by Emmsleys. Go to Solution.
Solved by pendean. Go to Solution.
Following up on this thread, were able to try the suggested steps?
Please post back in the thread if you are still having an issue with AutoCAD the community and myself will be more than happy to help.
To add to this thread,
You can view language packs based on your release at the following links;
Please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
