AutoCAD stop working while Plot to pdf!!
mazurkiewicz_przemyslaw
Observer Observer
Message 1 of 10
Observer
Observer
I’ve got problem while I am creating pdf drawings. AutoCAD stop working every time I trie to do it. „Sending plotter to pdf” and nothing is going on. I got this problem yesterday, before that it worked well. How to fix it?
Replies (9)
Message 2 of 10
imadHabash
@mazurkiewicz_przemyslaw
Autodesk support team has looked into this issue and has released THIS SUPPORT DOCUMENT with everything you need to know about this and what you can do.  Hopefully this helps!
Imad Habash
Message 3 of 10
paullimapa
Questions:
1a) What pdf device are you using?
1b) Enter Plot command, do a screenshot & share that here
2) Does the problem occur on a blank dwg?
3) What version of AutoCAD are you using?
4) Do you have the latest updates installed?
Enter About command, do a screenshot & share that here.
Paul Li
IT Specialist
@The Office
Message 4 of 10
Observer
Observer
1) Adobe Acrobat
2) it freeze everytime when I plot to pdf
3) 2026
4) updates of what? system? - Windows 10 PRO 22H2 updated yesterday
Message 5 of 10
paullimapa
1) Your Plot window screenshot actually shows that you're using a built-in AutoCAD device called DWG To PDF.pc3 & not Adobe Acrobat.
Does the problem occur when you plot using DWG To PDF.pc3?
Also when using DWG To PDF.pc3 instead of User 1 why not use the built-in ISO A3 paper size?
3 & 4) Is about AutoCAD:
Paul Li
IT Specialist
@The Office
Message 6 of 10
Observer
Observer
I use DWG to PDF for 10 years and it always worked.
I use User 1 because use various types of paper size - roll paper, e.g. 297x800mm, 420x650mm.
Does the problem occur when you plot using DWG To PDF.pc3 - Yes, but the problem started yesterday. Everything was working fine until yesterday.
Message 7 of 10
Joseph_N_PTI_Transformers
Community Visitor
Community Visitor
I've had this issue as well
Message 8 of 10
paullimapa
The way I like to test is always go back to the basics which means:
1) built-in pdf device, ie: Dwg To Pdf.pc3, AutoCAD PDF (Smallest File).pc3, AutoCAD PDF (General Documentation).pc3, AutoCAD PDF (High Quality Print).pc3
2) built-in paper size ie: ISO A3 (420.00 x 297.00 MM)
3) a blank dwg
Does it still lock up when you've tried that?
Another thing to try would be to reset your LT:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-reset-AutoC...
Paul Li
IT Specialist
@The Office
Message 9 of 10
CGBenner
@mazurkiewicz_przemyslaw @Joseph_N_PTI_Transformers
Hello, and welcome to the forum!  Have you both had a chance to look over the post made earlier in this thread by @imadHabash?  It appears to have a solution from Autodesk that could help.
Did your question get successfully answered? Then just click on the 'Accept solution' button.
Let us know how we did on Trustpilot.
Thanks and Enjoy!
Chris Benner
Message 10 of 10
paullimapa
The solution would not apply to @mazurkiewicz_przemyslaw since the problem occurs on Windows 10:
Re: AutoCAD stop working while Plot to pdf!! - Autodesk Community
Paul Li
IT Specialist
@The Office
